Solenoid Valve
Hi
I have 2002 SE with 181K miles on it, had being going through transmission slip and ran scanner, I got P1259, P0780, P0700 codes. After doing a little google it was indicating towards shortened Solenoid Valve A replacements or Transmission filter replacements. My question is which Solenoid valve I should use to handle this situation? Also is it worth to try repairing transmission filter alone? has anyone gone through similar situation? Please advice. Thanks Regards Navee |
I've moved this to General Tech - Please do not post questions in the DIY section, there is a sticky at the top of that section about this.
The 0780 is not a good sign = mechanical problem in the hydraulic system.
You can try changing the solenoids (A and B), I'd get them from a bone yard. In the end, I'm going to guess the trans is toast. If you go for a rebuild be sure the shop upgrades the valve body - http://www.sonnax.com/system/pdfs/35...pdf?1320330979 |
Hi
Thank you so much for inputs. I called up mechanic and asking him to replace fluid and see if I can drive till I find a good replacement from mechanic or junkyard Thanks for help |
Some have driven for a long time (weeks, months, years) with the trans acting up. The fluid change might extend the period of time it lasts. Read the link I posted, there is a company that seems to have figured out "why" the trans in the 98-02 Accord (and a few other Honda's - Ody, ect) in this year range fail. Point being, a use one from a bone yard is prob going to be a crap shoot.
Also, sorry, for the 1259 - please check the oil level. If close to being due for a change.....change it. 90% of the time that code comes up when the oil level gets low. |
Hi Poorman212,
Thank you so much for your response... sorry I was bit busy to respond as well try. Yesterday I called up a mechanic and he helped me to drain entire oil from transmission and we filled it with castrol transmission fluid 2 bottles and 1 bottle of lucas transmission slipping fluid. Yesterday it drove nicely without any problems but today I'm back to square one. I also observed now during my drive for lunch there was little noise in my engine. I'm going to run scanner once I go home today and call mechanic tomorrow to have it tested. I am going to give one more try before I go to boneyard to get another transmission. Any other suggestions or inputs to handle this situation? I really like my car and started doing a bit of improvements to it after my purchase. Regards Navee |
Again, please check the engine oil level to be sure it is ok......if you are close to change then I would go ahead and change it.
As far as the trans, well not much more I can think of. |
Thanks
I have drained & filled engine oil 4 weeks ago with Jifflube, I took their signature services. Infact all transmission problem started after doing a oil changes, initially had a D3 light blinking which changed after putting transmission into R and then D1, D2, D3, D4. Yesterday mechanic coudlnt come, hope today he comes and resolves this issue. Though I took car in neighborhood with that noise. Will update tomorrow. thanks for all help |
