Spark plug changing
Old 06-30-2007, 09:03 PM
Default RE: Spark plug changing
He has a '98, would the same plugs (NGV V-Power) be the best bet for my '97?
And Honda wires are best, can i get these off AutoZone or anyother place? Can i get it from the dealership? If not, whats my best 2nd option?
Old 06-30-2007, 09:49 PM
Both AutoZone and Advance auto have those brands of plugs in stock most of the time..
Old 07-01-2007, 12:01 AM
I know i can get the plugs there, but can i get the Honda wires there?
Old 07-01-2007, 01:30 AM
YeuEmMaiMai's Avatar
honda oem plugs (NGK) only. all you need is a ratchet, awire sparkpluggapper,and a 12" extention along with your spark plug ratchet. you can do it in 15 mins under normal condition. I changed my plugs on my 94 in a about 10 mins
Old 07-01-2007, 01:08 PM
LCSeminole's Avatar
I just tried getting the NGK PZFR5F-11, (oem for my 2000 Accord EX-V6) at AutoZone yesterday and they said they don't carry NGK, so I ordered off of www.sparkplugs.com. For those of you in the know, are the Iridium NGK's for my car as good as the OEM's???
Old 07-06-2007, 08:57 AM
maro's Avatar
I have the irridiums. They are the needle nose tips. They have worked great from me. Honda Dude mentioned that they sometimes lead to cold start problems. Because of this, especially in the winter, I turn the engine on for a second before turning the car over. That should avoid any cold start issues. However, next time I will buy the NGK OEM's
  #17
Old 12-08-2007, 01:58 PM
Nishdog007
what do you mean by "turning the car over"?...
  #18
Old 12-08-2007, 02:10 PM
sir_nasty's Avatar
when you try to start the car the starter pops out and engages the flywheel and rotates the crank/pisons etc. This is commonly reffered to as "turning it over" that intiall attempt to start it.
  #19
Old 12-08-2007, 08:01 PM
drummer1279's Avatar
Standard NGK's or NGK platinums are all good, iridium plugs are only good if you do 80% or more open road/highway driving because they have a cooler spark.
  #20
Old 12-10-2007, 10:35 AM
falkore24's Avatar
Iridium or silver are the way to go if you spray nitrous. Nitrous breaks the bond between the plug and the platinum, so no platinum plugs for juiced cars!
Iridium plugs won't work with MSD or any other capacitive discharge ignition because the high power spark will fry the tip off.
The best plugs are as follows:
No special ignition system or nitrous: NGK Double Platinum
Nitrous installed: ZEX plugs or NGK iridium
Capacative ignition: NGK double platinum or ZEX
Capacitive ignition and nitrous: Don't try anything other than the ZEX plugs!!!
Quick Reply: Spark plug changing
