Spark plug gap for a 1993 Accord 4cyl 5spd
Old Oct 18, 2014 | 11:50 PM
93Accord2.2's Avatar
Default Spark plug gap for a 1993 Accord 4cyl 5spd
I tried opening them up to 0055 to see what would happen and it still runs fine, you can revv it up at idle or get on it while driving and there's no discernible miss or roughness, but, I've killed the engine twice when taking off from a light within three days after going to 0055 .. which would happen maybe once every year otherwise, and I swear it may be making a bit less power now..
If less of a gap makes a hotter spark and more of a gap makes a bigger spark, which of those is better?
A wider gap definitely leads to reliability issues from what I've read.. The electricity can't jump across as easily. So there it is stressing the coil more and it's less likely to start up under certain conditions. Right?
Like say I'm out there trying to start the car after there's been three days of rain. My car occasionally doesn't like to start in conditions like those ... A wider gap would definitely make that situation worse, yeah?
What would happen if I dropped down to 0030 or so? As I understand it I'd have a far more reliable spark, the coil would be happier, and the sparks would be hotter..
Old Oct 19, 2014 | 08:41 AM
Gap recommendations of Honda are best.
Wider gaps will result in premature coil failure. Specifiation is 0.043 inches.
tradosaurus
Jul 21, 2011 12:30 PM
theirlaw
May 8, 2009 01:14 PM
gshock
Feb 23, 2009 12:24 AM
trukid21
May 2, 2007 03:55 AM
trukid21
Apr 29, 2007 01:46 PM
