Specification of AC evaporator connection?
Can anyone tell me the specification of threads that are on the hose connection of the air conditioning Evaporator on 1994 Honda Accord?
Thanks |
What are we trying to do?
You might be able to look up the evap and get the spec's on it to figure out the answer????? |
torque specs???
RECEIVER PIPE TO EVAPORATOR Torque 13 Nm (9.4 lb ft) SUCTION PIPE TO EVAPORATOR Torque 31 Nm (23 lb ft) |
I'm using the Heater & AC box that fits under the dash of a '94-'97 Honda Accord in a 1937 Buick Roadmaster.
The HVAC fits perfectly under the dash. The engine I'm using is an (LT1 V8) and AC compressor are all from a 1995 Buick Roadmaster. I need to have custom AC lines that connect from the a) GM compressor to the Accord Evaporator and b) from the Accord evaporator to the GM drier receiver. What I'm looking for is the thread specifications that are on the 94-97 evaporator at the firewall. Thanks EPS3 |
COOL.....let me try a bit of digging and I will get back with you.
Thanks for looking
1 Attachment(s)
Not sure if this helps but all I've been able to find so far. You can check four seasons (4 Seasons - Home) for more details. As far as I can tell, to date, the threads are standard threads and you just need to get the correct hose size......hope this is of some helps.......54187 is their part number for the evap.
Thanks for your help. I'll bring it into a place that does hoses and they'll probably be able to help me out.
Pic's at some point would be nice :), please.
I'm a fan of the old Chevy's....... |
