-   -   Speed-O Off (https://www.hondaaccordforum.com/forum/general-tech-help-7/speed-o-off-66222/)
Drewzer Oct 24, 2018 03:12 PM
Speed-O Off
I picked up a 2000 LX V6 and the speed-O is running fast by nearly 10 MPH. I looked through the maintenance paperwork that came with the car and found that the trans was changed at about 100K miles with a "used" one. Anyway, are there multiple Speed Sensors for these trans, and if it's not a speed sensor what could it be? Any and all opinions are welcome. Thanks, -Drew from San Jose CA.
The Toecutter Oct 25, 2018 04:11 PM
What size tires are on it? I think they should be either 195-65-15's or 205-60-15's. If they're smaller than those 2 sizes I listed, then that's part of the problem.
Does the cruise control work and hold? Just asking as you may have a VSS sensor going bad.
Drewzer Oct 25, 2018 06:27 PM
The tires on the car are 205-65-15s and yes the cruise control works well. I'm thinking it's the wrong VSS and that means the trans came from a truck or van. Not Good!
The Toecutter Oct 26, 2018 03:53 PM
Well, since you're running taller tires, the VSS is definitely out of calibration. Most Hondas I've found read about 2 to 3 mph fast.
