-   -   Speedo not working (https://www.hondaaccordforum.com/forum/general-tech-help-7/speedo-not-working-27521/)
valerie Aug 22, 2009 05:39 PM
Speedo not working
I HAD a D4 flashing light and a check engine light and speedo not working , so I researched and a common problem was the VSS. I replaced it with an Ebay one. It was not hard, just very hard to get to. Now the D4 is not flashing anymore and the check engine light is off, but the speedo is not working still.
I have read about a speedo head but not sure what it is.
What should I do next besides check codes because I can never do that right?
valerie Aug 22, 2009 07:39 PM
Forgot to mention that right after I got the coupe the d4 started flashing and the speedometer and odometer stopped working.
Now no flashing lights but the speedo and odometer don't work. Grease under my nails, a back ache from bending over and its still not fixed.. grrrr..
TexasHonda Aug 22, 2009 08:28 PM
Are you sure you inserted the tiny link between the VSS and the axle drive gear? If you lost this when removing old VSS and failed to insert a new one, this would account for no speedometer movement.
Have you noticed whether the odometer is working? If yes, the VSS signal is being transmitted, but speedometer circuit or movement is damaged. You will either have to pull and replace the instrument panel, or send your panel off to be repaired. Check www for sources of this service and check for posts on same subject.
If odometer is not working either, then you may not be getting a VSS signal to the instrument panel. Check wiring (org) and all connectors.
deserthonda Aug 22, 2009 10:22 PM
http://techauto.te.funpic.org
on the upper left side under REPAIR GUIDE you will see VSS click on it .. Hope this helps ..
Also if you look at the pictures under VSS REMOVAL ,, Texas is talking about the little drive link to make sure that you reinstalled it
next time you do some work on your car you might want to wear a pair of those thin latex gloves....No grease under finger nails :-)
valerie Aug 23, 2009 10:23 AM
Cool, thanks. In the trouble shooting section on the VSS page it says to check for voltage, and repair the "open" , what its the "open"?
PAhonda Aug 23, 2009 01:39 PM
An open would be the wiring fault that is causing you not to get voltage at the VSS.
valerie Aug 23, 2009 05:30 PM
Just went to the market and on the way it was not working, but on the way home it started working. Does that make any sense?
PAhonda Aug 23, 2009 05:42 PM
When the speedometer stops working, try to use the cruise control. If the cruise control works, then the VSS is sending out the right signal.
Does the speedometer needle go to ~19 mph when its not working?
valerie Aug 23, 2009 09:28 PM
No, it does not move at all. I tried the CC when I had the d4 flashing and it would not work. It is still working. Yay!
valerie Aug 26, 2009 02:55 PM
So it is not working 100% of the time anymore.
Now I just have no speedometer. D4 is no longer flashing and no CEL.
Cruise control works, even while the speedo is not.
