SRS Light
Old Jul 6, 2008 | 03:24 PM
jtbnorm
Default SRS Light
2003 accord 4 cylinder. having an issue with the srs light remaining on after start up. doesnt happen everytime. any ideas?
Old Jul 6, 2008 | 05:17 PM
Default RE: SRS Light
When a light comes on and stays on, it means that the SRS control unit detected a problem and likely stored a code. You will need that code to help determine the problem, because there could be numerous causes for this to happen. Post that code on here, then we can help.
I would look in your owner's manual to find out if there is a way to access that information through the navigation screen, because I am not sure if the OBDII scan that Autozone does for free picks up SRS codes.
Old Jul 7, 2008 | 08:58 PM
jtbnorm
ran obdII yesterday, no codes popped up. no nav screen. owners manual basically tells me to get to the dealer for check up or die.haha. thanks for your help PAhonda..
Old Jul 7, 2008 | 09:02 PM
njmodi's Avatar
OBD will not report SRS codes. You may have to go to Honda. In older models, the occupant detection system (something that lets the airbag system know if there is or isn't an occupant in each seat) was a common fault - Honda fixed those for free - your problem might be the same.
OneEyed
Jun 25, 2015 05:32 AM
brayner
Feb 12, 2013 06:59 PM
01AccordLX
Apr 4, 2012 01:39 PM
01hondaccordlx
May 18, 2005 11:51 PM
bj70alex
Nov 22, 2004 01:56 PM
