SRS light
Old Jun 6, 2006 | 02:58 AM
2002haccord's Avatar
Default SRS light
Recently the SRS light on my 02 accord turned on and stays on does anyone know how to clear it or why it might be on?
Old Jun 6, 2006 | 03:06 AM
Default RE: SRS light
Hi Member...Why would you wish to clear it without knowing even why it came on.
The idea with these lights and codes coming up is to take care of the problems that makes them come on in the first place.
You can go to AutoZone and for $ 69.00 buy yourself a cheap code reader which has the clear function on it..problem is that you shall still have the problem...
Old Jun 6, 2006 | 12:46 PM
Thats true does anyone know why the srs light would come on?
Old Jun 6, 2006 | 01:44 PM
sir_nasty's Avatar
I don't know if this applies to that specific year/model but in some of them there is sensors in the seat and if a person is sitting on the side for example or if you somehow turned it off then it would/could come on.... once again I don't know about this one... go down to autozone and they will read the code for you for free... then post it here and we can tell you...
Old Jun 6, 2006 | 02:25 PM
deserthonda's Avatar
call the local dealer might be under warranty
Old Jun 6, 2006 | 08:35 PM
Chiovnidca's Avatar
ORIGINAL: 2002haccord
The trouble code will tell you.
Old Jun 7, 2006 | 04:36 AM
jhopper1
in my case in the past few months before a honda co recall on the SRS systems. prior to the recall, they just said that they had to reset the computer. kinda like the radios for example with cell phones (that lil tapping you used to hear from cellular interferance). check on your warranty and you may be able to get it replaced and updated for free. maybe even a refund.
Old Jun 7, 2006 | 04:16 PM
SKHEMR's Avatar
Mind use to flash and I think it had something to do with the seat belt, if I un hooked and fasten it again it would stop.
When I disconnect the air bag to change my steering wheel it stayed on. I took it to the dealer and had it reset for 80 bucks, after trying to reset it with my code reader. I has nothing to do with the ecu there is something under the hood that they tap into.
Old Aug 17, 2006 | 07:00 PM
locovaca's Avatar
JHopper1, or anyone else, can you expand on this recall on the SRS system? My light came on today for no apparent reason (drove back to work from lunch it was off; got in 2 hours later and it stayed on). I'm not really willing to pay a dealer to reset a light when I can do it myself, but if there's a recall then I can use that. I looked up stuff and the only thing I could find for an acknowledged problem was this: http://www-odi.nhtsa.dot.gov/cars/pr...h&summary=true (which wasn't a recall).
Thanks!
Old Aug 17, 2006 | 08:04 PM
Ask the dealer about the recall. Because they'll want your VIN so they can look it up.
While you're on the phone with the dealer, ask them about the seatbelts & SRS system being WARRANTIED for the life of the vehicle...
