SRS lights up on my gauge cluster
Old Apr 4, 2008 | 10:48 PM
95coupe
Default SRS lights up on my gauge cluster
I picked up a steering wheel for my 95 Coupe EX from a local yard. Wheel only my airbag was fine. I replace the wheel and plug in all connections. When I went to reconnect the negative battery terminal and fire the car the "SRS" light came on the speedo cluster.
Do I need to flash the computer?
By the way I picked up the steering wheel for $10 WOW.......And after some cleaning it was in great condition.
Old Apr 5, 2008 | 01:00 AM
Default RE: SRS lights up on my gauge cluster
Short the service connector under the glove box. Look at CEL instructions on http://www.dhost.info/accordinfo/
The SRS codes are a main code and a sub code, ie 1-4. Find out what the code is. To clear the code, you have to find the service connector in the dummy plug near the fuse box (drivers side). It is a yellow wrapped wire harness. You have to short the connector, then unplug it, then short it again at the appropriate time.
That site I linked above has a shop manual for a 94 accord, so download the SRS. More detailed instructions are in there.
Old Apr 7, 2008 | 01:21 PM
95coupe
OMG...........Thank you very much.
Old Apr 22, 2008 | 12:25 PM
automan
Hi, I have the same problem on my 2000 Accord EX (4Cyl). Tried fixing at dealership and not successfull. Any suggestion on how to fix or clear SRS light. Thx...
SPBAV6
Sep 27, 2013 09:47 AM
t00fatt
Jun 1, 2007 08:23 PM
steviebix
May 6, 2007 01:32 AM
dcrusupra
Jul 19, 2006 02:24 AM
marbro
May 20, 2006 10:13 PM
