Antenna Replacement....HELP
Old Apr 14, 2008 | 12:32 PM
t12355
Default Antenna Replacement....HELP
I own a 1993 Honda Accord which has the power antenna that pops up and down when the radio is turned on and off. Does anyone out there know if it is possible to take that out and install a standard, regular antenna?
Old Apr 14, 2008 | 12:43 PM
sir_nasty's Avatar
Default RE: Antenna Replacement....HELP
yes, you just remove that antenna then you'll find a power wire that runs from the stereo (usually blue) disconnect that wire, put in the new antenna, cap/tape off the blue power wire, hook up the new antenna and you're done, just access the antenna from inside the car and it will be very straight forward from there.
Old Apr 22, 2008 | 10:29 AM
t12355
Hey, thanks a lot! Appreciate the advice!!
Old Apr 22, 2008 | 12:42 PM
I recently replaced the power antenna in my 94EX w/ a fixed, flexible whip antenna. It's available on ebay for about $30. I tried mast replacement and tinkering w/ gear box, but still would not go fully down and had a very annoying grinding noise at end of run buth up and down. Silence is golden.
LambertJohn
Sep 17, 2010 01:47 PM
hondadude
DIY Answers.
Oct 7, 2009 08:23 AM
james750
Jul 31, 2009 07:56 PM
HuYnHness
Apr 30, 2007 12:42 AM
Burnzy
Jul 17, 2006 01:20 PM
