base timing ?? ign
Old Apr 22, 2008 | 02:55 PM
boostedsupra
Default base timing ?? ign
i searched andread on the 94,to jump the blue terminal under the pass-side dash. does this work for the 92, as well? is it 12* ?
thanks in advance,
nick
Old Apr 22, 2008 | 03:05 PM
sir_nasty's Avatar
Default RE: bast timing ??
I'm not certain what exactly you are asking?
Old Apr 22, 2008 | 03:30 PM
boostedsupra
ORIGINAL: sir_nasty
fixed. sorry. was in a hurry.. also, i can't find the indicator on the timing cover!
Old Apr 22, 2008 | 05:36 PM
The service connector is the same setup on a 92. A code 12 is for the EGR system. You might need to clean the ports on the intake manifold. Google T2T013.pdf and that will give you the egr cleaning procedure.
The 92 doesn't have the timing pointer on the timing belt cover like the 94s have. There is a small cover below the distributor that you need to take off. If you download the 91 shop manual on the online manuals thread in the DIY section, the instructions are on page 5-29.
Old Apr 22, 2008 | 05:49 PM
boostedsupra
^ Thank you!
bob5528
Jun 13, 2011 12:40 PM
randy93
Jun 25, 2007 10:40 PM
Philthy
Mar 14, 2007 03:47 PM
beaterhonda
Jan 6, 2007 10:40 PM
