Stalling accord
Old May 28, 2007 | 12:25 PM
johnny123
Default Stalling accord
I changed the fast idle and iavc idle sensors and althougfh it runs better it still will stall on occassion. Sometimes aftrer it stalls the "S" light will start blinking. anyone have any suggestions.... Thanks
Old May 28, 2007 | 01:53 PM
Default RE: Stalling accord
First tell us what year/model Accord. You should add to your signature line to avoid this in future.
S-light on early 90 models was caused by a trans code being set. Short the service check connector and read S-light flashes for the code. Long flash for 10's digit and short flash for units for 2digit codes. Some codes are single digit, short flashes only.Post the code for help.
Old May 28, 2007 | 02:33 PM
johnny123
1990 honda accord dx
other than this problem motor runs fine
Old May 28, 2007 | 04:21 PM
johnny123
The troble code is a 7, throttle position angle? Where is that sensor located? Is it easy to replace.
Thank You.
Old May 28, 2007 | 05:14 PM
The throttle angle sensor is not available as a part, and entire throttle body w/ new sensor is sold by Honda. Only option is to buy a used throttle body assy. I found them at car-part.com for < $50 readily available.
It is possible that you have damaged wiring or damaged connector to the throttle angle sensor, or a faulty A/T control unit. You may want to download a shop manual from http://www.hondahookup.com/manuals/and go through the diagnosis chart to insure it's not relatied to the wiring.
Old May 28, 2007 | 07:31 PM
johnny123
Thank you for the help. I will check the wiring as well as finding if needed a used unit.
John
Ayam A. Mowran
Mar 25, 2007 05:27 AM
needhelp
Sep 27, 2006 02:09 PM
eckhart
Apr 7, 2006 12:32 PM
thigley
Jan 5, 2006 11:46 PM
mercski
Nov 26, 2004 07:39 PM
