starter removal instructions
Not too long. The starter is held in by two bolts. You might have to get creative to get enough leverage on the bottom one.
First disconnect battery cables at the battery, then disconnect them at the starter. Unbolt the starter. You will have to move the lower radiator hose out of the u-shaped clamp to make some wiggle room. I had to unplug the ECT sensor to get enough room to pull the starter out. You will have to maneuver the starter a bit to get it out of there, but it isn't too bad.
New2JDM
Apr 1, 2012 07:53 PM
93Miata
Nov 10, 2005 08:06 AM
tiffany
Apr 29, 2005 07:17 PM
06, 2005, 2007, 95, accord, acura, honda, instruction, instructions, manual, removal, replacement, starter, steps, tsx
