Starting Issues
Old Oct 29, 2011 | 08:19 PM
clane1012's Avatar
Default Starting Issues
I am having a similar problem getting power to the small wire. I have verified that Main relay is working, ignition switch and power at the fuse box. Any Ideas where else to look? PLEASE HELP!!!!
Old Oct 30, 2011 | 07:05 AM
Year and trans please....I keep asking about the trans as the system testing is slightly different between an auto and a manual.
Also assuming there is not a security system installed - factory or aftermarket.
EDIT: I've moved this....you posted under two other threads, on for a 94 and one for a 91. The gens (4th and 5th) are some what the same but....
Old Oct 31, 2011 | 08:09 AM
clane1012's Avatar
I found it, it was the clutch switch.
clane1012's Avatar
91 maunal
Old Oct 31, 2011 | 11:04 AM
Glad you worked it out.
If someone else reads this thread, you can unplug the switch on the clutch pedal. It should have two wires. Take a piece of wire and jump (connect) the two wires on the electrical connector. See if your car will start.
Slowaccord
Aug 28, 2007 08:38 AM
sir_nasty
Feb 7, 2007 04:19 PM
MRMASON
Oct 3, 2006 07:09 PM
brad6841
May 22, 2006 09:38 AM
brad6841
Apr 13, 2006 06:20 AM
