starting problem 96 accord lx 5spd
Old Oct 31, 2011 | 11:19 AM
tanhanson94's Avatar
by like turning it back and forth or in and out with the key?
Old Oct 31, 2011 | 11:45 AM
Try both. I was thinking in the direction that you normally turn the key. You can try pushing/pulling the key towards the side windows as well.
Old Oct 31, 2011 | 03:55 PM
If it turns out to be the starter and you have a Denso starter, you may be able to just replace the contacts, or the contacts and plunger and have it working again.
See these links:
"http://www.nationsautoelectric.com/densoparts.html"
"http://www.team-integra.net/forum/19-projects-diy-article-talk/76298-rebuild-your-starter-less-than-20-a.html"
You do need the right contacts part #s for your application though, as what is listed for the Integra may or may not be the same. Honda doesn't carry the repair parts; but, Toyota does, in addition to aftermarket sellers.
Copy & paste without quotation marks to view.
Old Oct 31, 2011 | 04:05 PM
Nohing happened while wiggling the key
Old Oct 31, 2011 | 07:14 PM
k24acura's Avatar
Originally Posted by tanhanson94
so what about it shutting right off if i dont give it gas right after it turns over?
Again fuel psi is dropping, had the same problem with my civic turned out to be regulator. Check the regulator fuel filter and pump.
Old Nov 1, 2011 | 09:40 AM
So would that be the cause of it taking long to start too
Old Nov 1, 2011 | 12:26 PM
  #17
Fuel pressure could cause difficulty in starting, however it would not cause slow starter turn-over.
From your post, I thought you had a slow turn-over problem. I know you had a problem w/ cut-off after starting, but let's solve one problem at a time.
Old Nov 1, 2011 | 05:26 PM
  #18
k24acura's Avatar
The initial crank the fuel psi is not high enough so injection is off. There fore none of the piston are not igniting correct giving you a slow crank.
Old Nov 1, 2011 | 08:44 PM
  #19
Not IMO, but you decide.
Old Nov 2, 2011 | 10:05 AM
  #20
so what should i go about doing?
