Steam coming from 2004 Accord EX
Old Apr 9, 2009 | 12:51 PM
RTM1216
Default Steam coming from 2004 Accord EX
My 2004 Accord EX (4cyl) started acting weird yesterday. When running and just idling for about 5 mins I've been getting a burst of steam coming from the engine compartment that lasts about 2-3 seconds then stops.
The temp gauge is showing a normal temp (a little below the halfway mark) so it's not overheating. The steam is coming from somewhere on the passenger's side as I can see condensation and a little pool of coolant on top of the plastic cowling near the a/c compressor. Any ideas on what could be causing this?
Old Apr 9, 2009 | 01:09 PM
RTM1216
I forgot to add... The CEL is not on.
Old Apr 9, 2009 | 06:27 PM
deserthonda's Avatar
fix the coolant leak..pressure test system to locate the leak , once fixed i bet you won't see steam any more
Old Apr 9, 2009 | 07:11 PM
Make sure it's coolant and not AC lubricant, which sometimes is also green. Pressure relief valve on compressor releasing might leave lubricant behind and you might see some "steam" when a release occurs in humid conditions.
Old Apr 10, 2009 | 07:56 AM
RTM1216
Thanks. Is it normal for the compressor to release pressure or is it an indication of some other issue?
Old Apr 10, 2009 | 11:32 AM
No, it is not normal.
Pressure release could occur due to condensor blockage, cooling fan failure, or other reasons where compressor runs and very high system pressures develop. PRV releases somewhere around 400 psi and there will be a loud noise when this occurs.
Old May 4, 2015 | 10:54 PM
azcosta's Avatar
Had a similar issue with my 05 V6 Accord just this weekend. However mine started with a completely dead battery. Jump started and ran it up to temp and got it charged up. Randomly shut AC off inside the car and got a rough, very low idle, then all of the sudden this big burst of vapor for about 1 second from near the AC compressor. Search across forums found similar problem resolved by others as a faulty AC relay switch. Sure enough one of the three AC relays in the underhood fuse box was bad when bench tested. Replaced with aftermarket for less than ten bucks and solved the problem. Think the compressor was not being relieved of high pressures so it did it on its own via the pressure release valve. Loud and strange.
Old May 5, 2015 | 07:43 AM
Most sources I've heard recommend replacement of PRV if it actuates as it may tend to leak afterward.
BMWright92
Jan 14, 2012 11:27 PM
desfam5
Sep 22, 2010 11:56 PM
nitika
Aug 31, 2010 12:20 AM
cbinva
Feb 24, 2008 06:14 PM
crvone
Oct 25, 2007 12:05 AM
