Steering pressure not constant
Old Sep 26, 2012 | 02:04 AM
powerpro369's Avatar
Default Steering pressure not constant
I have looked high and low for an answer to this question but I have not seen anyone have a similar question.
As I take a turn I can feel the steering wheel slip (Slightly) as though the pressure goes from normal pressure to a lighter pressure. It doesn't make the drive unsafe but I really don't like not having a solid and constant feel.
What I have checked so far...
--Replaced the serpentine belt
--Fluid is between the min/max line
--No leaks
Could this be in the rack and pinion? Maybe the shaft sticking? Or could there be air in the system? If so, how do I purge the air? Does anyone have any thoughts to this annoying issue?
Old Sep 26, 2012 | 05:45 AM
Many Hondas have a problem w/ a leaking oring on the suction return fitting at the pump. This allows air to enter and causes noise and variable steering boost as air "softens" the hydraulic fluid. If you hear whining/roaring noise at times from the pump, this is highly likely.
It can also cause PS fluid loss as the foam will overflow the PS reservoir sometimes when you stop.
Old Sep 26, 2012 | 08:12 AM
Is this on some kind of Accord? Not all years 1976-2013 are all the same. There's some years that have speed-sensitive steering boost.
Old Sep 26, 2012 | 07:00 PM
Totally with TX and Jim.
My two cents, if the miles/years are do or someone has done work on the PS system before, a PS fluid flush might be needed.....Honda's are VERY picky on PS fluid and Trans fluid. So the point, be sure that Honda/Acura approved PS fluid is used.
Old Sep 26, 2012 | 07:05 PM
Dr. Drivability's Avatar
sounds symptomatic of a bad rack/pinion too...what year/engine is it?
jdubicki
Jan 7, 2019 10:55 PM
Accord-Coupe-De-Grace
Jun 2, 2010 11:57 PM
IWL BCNU
Aug 5, 2009 02:24 PM
username89
Sep 4, 2007 12:34 PM
isaacjson
Jan 28, 2006 11:42 PM
