Steering Rack 1995 Honda Accord 2.7l LX
so I believe all the oil leaks are buttoned up and there is a small leak coming from the front center, just off center to the left. the mechanic told me there was a steering rack leak.
so I need advice. car drives perfect, no steering issues at all. just leave the leak? I have not had to add Power Steering Fluid into the reservoir.
If I were to do a replace of the rack, do I get a refurbished? and if so is there a preferred brand for 1995 Honda Accord LX? someone recommended Maval refurbished.
any advice is appreciated.
bt
bt
If you can see the leak, then it might not be PS fluid. Keep a close eye on the engine oil, trans fluid, and brake fluid.
I'm not sure where you are seeing the leak, so you may want to post a pic. Take it from up close then from further back, so we have some references on the engine block.
I'm not sure who does quality rebuilds I'd probably try to clean up the leak and PS rack as best you can, then try to pinpoint the leak. Athlete's foot spray on a clean block can help track the source of a leak, because the leak my be higher up on the engine than you realize.
bt
darkgreen18290
Jun 25, 2013 07:51 AM
