Steering/stability issues?
Hi, We've got an '07 Accord that my wife wrecked once ...right front tire folded underneath from an impact with a telephone pole. Obviously a lot of work was done, but I'm not sure what. The car is fine around town in general, but I notice a tendency to oversteer, a tendency for the front end to wander a little (like a worn front end does - loose steering type of feeling), and when accelerating, it'll pull to the right. I'd be surprised if Honda designed a car that would pull to either side when accelerating. The car only has 70k miles on it, all pavement, mostly city. Since we live in Alaska, and drive on a lot of black ice, the oversteer and tendency for the rear end to want to 'come around' is a safety issue.
- It drives like it has loose tie rod ends (etc) ...but the car is relatively young? - Pulling to one side when accelerating - seems like something's missing? Steering stabilizer of some sort? Anyone? I might take it to a shop, say nothing about accidents, and let them find what's wrong ...Hopefully it's not a unibody thing (these are unibody cars, right?) Thx, Brian |
Suggest having alignment checked. Alignment error might cause oversteer (tendency to keep turning more than commanded) due to damage that was not correctly repaired.
good luck |
FWIW, here are some Honda service bulletins to give insight regarding probable causes, not including front suspension damage that the car may have:
Honda TSB 06-068 SYMPTOM While driving on a straight road, the vehicle pulls or drifts to the right or left. PROBABLE CAUSES Several conditions can cause the vehicle to pull or drift: • Wheel alignment • Tires • Steering wheel off-center (no pulling or drifting, but a customer may believe this is the case) ************************************************** * Honda TSB 03-036 SYMPTOM The vehicle drifts to the right at highway speeds. PROBABLE CAUSE The camber settings are uneven. CORRECTIVE ACTION Shift the front subframe to the right. |
