-   -   Stereo install - simple Q (https://www.hondaaccordforum.com/forum/general-tech-help-7/stereo-install-simple-q-19577/)
atarikid07 Jul 7, 2008 03:23 PM
I've looked up the DIY on this, but I've just got one question.
If you look here:
http://www.installdr.com/InstallDocs...PDF/466053.pdf
On page 5 it lists a bunch of steps. Are these there, in case you don't buy the aftermarket wire harness? In other words, are the things on pgs. 5 and 6 irrelevant, unless you want to splice your own wires? Or is there an extra bit of information I am overlooking?
Also, is taking the dash cover and clock off easy? I dont want to break anything...
atarikid07 Jul 7, 2008 08:04 PM
RE: Stereo install - simple Q
Ok, so I got it installed. Now, I have a new problem though. After the installation, I noticed that my backlights to my clock and odometer don't work. How is it possible that this happened? And how do I fix this?
falkore24 Jul 8, 2008 08:11 AM
Check to see that you didn't blow a fuse during the install.
Asmir02 Jul 8, 2008 08:45 AM
Same thing happened to me! I check all the fuse they all work, I even try pluging back in my old factory radio and still doesn't work! I have the same car too.
Asmir02 Jul 8, 2008 12:42 PM
I found out the problem it was multiplex control unit driver side soo i got another one from honda parts it cost me $75 and friendreplaced it and now everything works fine. Make sure you get a driver side multiplex control unit.
open this up
http://www.driveaccord.net/forums/at...p;d=1196877500
read that and it will show you how to replace it.
falkore24 Jul 8, 2008 01:01 PM
Diagnose everything that can be wrong BEFORE buying ANY parts for your car. There is no simple answer for all problems that seem alike.
atarikid07 Jul 8, 2008 10:59 PM
It says on the pdf that this replacement should be done free of charge... How long do these recalls last for (assuming that my car falls under the VIN category)?
And what else could it be other than fuses? This has happened to me in the past, with the a/c strength dial backlight. That, however, fixed itself. Ideas?
EDIT:
I just realized that the recall only applies to LX Accord, not my EX. Wow, what a predicament.
falkore24 Jul 9, 2008 08:35 AM
Did you check the fuses? There are 3 panels on your car.
