Sticky Brake Light
Old May 11, 2013 | 12:08 AM
tlc1984's Avatar
Default Sticky Brake Light
The dash light for my E-brake is a bit fussy. Sometimes it wants to be on, other times off. Anyone have any idea why? I've checked the brake fluid, its fine. Also seems, but not always, that when its cold outside, it tends to be on more often than when its hot.
Old May 11, 2013 | 08:35 AM
What year is the Accord?
Old May 12, 2013 | 08:10 AM
tlc1984's Avatar
It's a 2000
Old May 12, 2013 | 10:49 AM
On the Accord in this gen (98-02) the fluid level sensor in the brake master will get stuck. There is a TSB on this.
Do you have a volt meter to do some testing next time it acts up?
EDIT: Wrong- Got the 6th and 7th gen's mixed up - 6th gen's the float is part of the cap. The 7th gens have the float inside the res and not part of the cap.
Old May 12, 2013 | 02:38 PM
You could also disconnect the wires at your brake-fluid reservoir. Not as a FIX, but for diagnosis.
If the lamp still is flaky, then you know it's not related to the brake-fluid level sensor.
The little button-switch under the handbrake lever is kinda simple. Maybe that's bent or something??
Old May 13, 2013 | 09:52 PM
tlc1984's Avatar
No volt meter, , where can i find this TSB?
Old May 13, 2013 | 09:57 PM
tlc1984's Avatar
i think i'll try the disconneting the wires. (just to test) and i dont think its the hand lever because when its warm outside (and the light is off) i move the hand lever up and down slightly, the light will react as it should. (on or off depending on whether its up or down.
Old May 13, 2013 | 10:12 PM
Supanova1981's Avatar
Replace the brake master cylinder cover, float and strainer... It's definitely related to the Tsb.
Old May 14, 2013 | 10:41 AM
tlc1984's Avatar
I found the TSB. Interesting information although paying monthly to view these are out of the question. I'll look at other sources for the information.
Old May 14, 2013 | 11:48 AM
I had this problem on 97 Acura TL and cut V-notches (scissors) in the strainer bottom centralizer on both sides. Problem was resolved.
