Still have surging and power issues
Old Aug 29, 2012 | 12:23 AM
AccorDats's Avatar
I solved the problem already, throttle has so much slack now it is tightened but not too much. Thanks for the inputs. More power HAF
Old Aug 29, 2012 | 01:35 AM
my1st.honda93's Avatar
Hey partner you mite want to do what i did before you go spend any hard earned cash!
What i did was take the entire air intake out(intake plenum)and clean the inside of it real good!what i used was a toothbrush and gas.
Its like cleaning the EGR ports only better!and clean the fuel injectors as well and throttle body.
Now you will need to buy 2 gaskets...the intake gasket and throttle body gasket,i believe i paid $27 for both.
do that then check to see how it runs?i had some what the same issue your having and i cleaned the intake,injectors and throttle body now she runs like a champ!
good luck!
Old Aug 29, 2012 | 08:45 AM
RobinsonRicer's Avatar
thats what my manifold swap was for
justmeedp@cox.net
Oct 5, 2014 08:14 AM
justin's91
May 10, 2013 05:05 PM
tiresthatgrip
Aug 10, 2011 05:32 PM
davidg99
May 5, 2011 11:59 PM
GOT BOOST
Nov 2, 2009 08:32 AM
