still on my accord 98 single cell radiator
Old Apr 19, 2013 | 09:30 PM
Rilex's Avatar
Default still on my accord 98 single cell radiator
hi everybody, i have accord 98 Lx, 4cylinders, 2.3L, auto trans. I am still getting worried and afraid about my accord single cell radiator whether it wil overheat on the way on a long journey[276km] i am about to make soon, although presently is not overheating and there is no leaks and no crack on it, I use coolant whenever there is drop in the fluid in the reserve tank and the radiator itself. My mechanic told me since is still new nothing will happen but immediately i come back from the trip i will change it to double cell radiator. Your advice and recommendations will be helpful. Thanks
Old Apr 19, 2013 | 10:29 PM
What is the problem with the radiator you have now? Does the OEM accord come with a double cell radiator?
This part is confusing. Do you need to add coolant? Is the mechanic going to install the proper part?
Old Apr 20, 2013 | 05:33 AM
Rilex's Avatar
I used to add coolant to the reserve tank when it is below minimum mark. The mechanic is not installing any part to it. The single cell radiator is working fine and not overheating. My question is can the one cell radiator cool down the engine for a journey of 31/2 hrs [276km] drive with A/C on? Here in Nigeria now the temperature is very hot that is why i am getting worried. I believe it will not overheat on the way. Thanks
Old Apr 20, 2013 | 08:36 AM
Roader's Avatar
"Very hot" is 40° or less? Your car was designed to withstand those temps, even with the A/C running and many hours running. USDM cars have single row radiators and easily cope with the 40°+ temperatures common in the southern US. How often do you add coolant, and how much coolant needs to be added?
Old Apr 20, 2013 | 09:45 AM
Rilex's Avatar
thanks to you Roader, the amount of coolant added is just to top it a little in the reserve tanks not that much, what is USDM? Since the single row radiator can withstand temps of 40+, I trust that the radiator will not blow up during those long hours of driving, I will try to change the radiator hose expecially the one above the radiator to make sure all is well during the journey. Thanks to you all in HAF
Old Apr 20, 2013 | 10:27 AM
Roader's Avatar
USDM is United States Domestic Market.
Worst case scenario is very high ambient temps + low speed driving + A/C running. You're right to make sure all the hoses are in good condition for such driving. Clean coolant and functioning fans/thermostat/radiator cap are a must too. Your radiator won't blow up if the radiator cap is working correctly.
Note that your car really shouldn't be losing any coolant. It shouldn't require frequent topping up of coolant. If it does then there may be a problem with the cooling system or another part of the engine.
Rilex
Jul 19, 2013 12:41 AM
Rilex
Jan 22, 2013 06:09 AM
smaglik
Oct 14, 2007 02:30 PM
19Accord97
Jun 26, 2007 10:57 AM
yank4life
Nov 13, 2006 09:42 AM
