Strange "bbvrrrrvrrvrt:" noise - 1994 Accord EX
Sitting at an idle I noticed that a strange noise is coming from somewhere around the pulley side of the engine (Driver side). It sounds a little like a grindig noise or a rapid buzzing noise and only sounds every few minutes for half a second.
Any ideas? I can't place it, the engine bogs down just a little when it happens. |
RE: Strange "bbvrrrrvrrvrt:" noise - 1994 Accord EX
Pop the hood and try to inspect stuff while it's running/idling, you can use a wooden broom handle as a sort of stethescope to help narrow it down, however, the most common issues for that would be an alternator or water pump.... I'm going to take a random guess at an alternator problem but it could be as simple as the belt needing replaced....
Your description suggest ABS unit is running to top-up pressure on the accumulator. You may have low fluid in the ABS reservoir, or possibly a leaking internal valve (not repairable). You can get the ABS code by shorting the Service Check Connector, turn keyswitch to ON,and reading the flashing codes. I've forgotten the code flash scheme but think its all short flashes w/ a pause between 1st and second digits. Check our DIY FAQ's for some further help on ABS or a shop manual if you have one.
good luck |
The ABS light does come on frequently.
That may be it. I will check codes. You say "not repairable". Is it replaceable? |
Do you have the A/C on when this happens? My engine bogs when the compressor kicks in, but it usually lasts longer than a few seconds. It is normally bogged for most of the time the A/C is on. Probably not what you are talking about, but just a thought....
I thought the AC too but it is off when it happens.
ORIGINAL: Drpepper The ABS light does come on frequently. That may be it. I will check codes. You say "not repairable". Is it replaceable? If the fluid level is low and you see evidence (fluid, shriveled looking paint) of brake fluid beneath your modulator, it can likely be repaired. There is a procedure to remove ABS modulator, tighten about 8 plugs in the modulator body, and re-install. PM me w/ your email and I'll forward the procedure. This fixed leaks on my daughter's 97 Acura 2.2 CL which shares the same ABS modulator as the 94EX. good luck |
Thanks for the advice, I am going to try to take some time to narrow in on the noise and do the inspections you recommend. I will let youknow what I see.
The noise is getting worse, It stays on for several seconds now when I initially fire up the engine. |
ABS controller resets every time engine is started and attempts to pressurize the ABS modulator. Have you checked fluid level in modulator? Low fluid level will cause this problem. Also get ABS code from controller.
good luck |
Yeah I had that problem on my 94 accord all I did to fix it was to bleed the abs pump modulator fairly easy to and got rid of my abs light too.
[align=left] [/align] |
