Stumbling 95 Accord
Old Aug 27, 2007 | 07:55 AM
skyking007
Default Stumbling 95 Accord
My 95 accord dx stumbles while crusing at steady speeds, anyhere from 30 to 70 Mph. Kinda like a shudder. Have tuned up and run injector cleaner and no result. It does not do it while cold. Can this be the Transmission. ???
Thanks Steve
Old Aug 27, 2007 | 11:17 AM
Default RE: Stumbling 95 Accord
It might be the tranny locking & unlocking the torque converter. Easier to say by driving it firsthand, it kinda feels different than a misfiring problem.
You'll get better answers by postingin the "General Tech Help" section. This "New Member"section is kinda general introduction & welcome. Some of us don't visit here all the time. Plus, list exactly what what was done for the tune-up that you mention.
So... Welcome to HAF. I hope we can help youfigure this out.
Old Aug 27, 2007 | 11:24 AM
sir_nasty's Avatar
Have you noticed any consitency between the RPM range when it happens? A semi-common issue for cars of that age is a stumble/shudder at around 2000-2500 RPM's regardless of speed, that happens due to plugged EGR ports. Also, with tune-ups on honda's stick with NGK spark plugs
Old Aug 28, 2007 | 06:02 AM
Happy to have you with us here in the HAF...
Thank You for joining!
Old Aug 28, 2007 | 07:54 AM
ORIGINAL: JimBlake
You'll get better answers by postingin the "General Tech Help" section...
LOL... someone must have moved the thread over here.
Old Aug 28, 2007 | 08:03 AM
skyking007
I used factory plugs and cap and rotor. Only thing found was a spark plug gasket leaked oil from valve cover to soak 1 wire, thought that was problem but not. Will look into RPM. That makes sense though. It never happens on accelaration just steady crusing speed 138,000 miles.
I will monitor the RPM. Thanks
Old Aug 28, 2007 | 09:32 AM
deserthonda's Avatar
i would also chk the plug wires,,
Old Aug 29, 2007 | 10:47 AM
skyking007
Stumble occurs 1500 to 2500 RPM. Will get EGR ports checked. What are these EGR ports
Old Aug 29, 2007 | 11:49 AM
ORIGINAL: skyking007
... What are these EGR ports
Passageways thru the head & intake for Exhaust-Gas Recirculation. The ports and/or the EGR valve can cause the problem. Maybe Desert has a DIY instruction thread over in the DIY section? (I didn't look)
Old Aug 29, 2007 | 11:59 AM
yep,,,,,,,there is a write up on how to cleak egr ports ( by Hondadude ) just go to our DIY section
but chk those plug wires first
