Sun/Moon Roof problems, help!!!
Old Aug 11, 2011 | 09:02 PM
562kid's Avatar
Default Sun/Moon Roof problems, help!!!
whats up i got a 98 accord ex sedan and the sun/moon roof combo was working right the first couple days and then all of sudden it didnt, the glass tilts up fine but it doesnt want to slide back....any suggestions on what could be the problem
side question here, is it possible to replace the fabric seats in my accord with the ones that come leather
Old Aug 11, 2011 | 09:14 PM
It could be the moon roof switch, one of the motors, or the wiring.
I would test the inputs using a volt meter on the moon roof. You could also test the switch as well.
I don't have a good shop manual, but you can get one for a 98 accord from automanualsource.com for $21.99 that you can download as a pdf.
Old Aug 11, 2011 | 10:34 PM
562kid's Avatar
thanx for the link, but im not really tech saavy, so where would i test the inputs at
Old Aug 11, 2011 | 11:00 PM
At the electrical connection(s) for each moon roof motor. Or the electrical connection for the windows switch.
You will have to test for voltage or continuity (open/closed circuit) on a wire. We can explain how to use a volt meter to test these items if you don't know how.
Old Aug 11, 2011 | 11:04 PM
562kid's Avatar
ooh ok...wouold the volt meter be the same as a multimeter tool, and at what voltage should it be showing
Old Aug 12, 2011 | 07:16 PM
Yes.....voltage, 12v. Continuity, zero resistance-at least that is how it reads on mine.
Old Aug 12, 2011 | 08:17 PM
skramer's Avatar
Check the track for obstructions. Ours did the same thing right after we go it. It would tilt up, but wouldn't go back. I looked carefully at the track and there was a small piece of rubber or something jamming it. It might not be your problem, but its free to check.
Old Aug 18, 2011 | 10:41 PM
562kid's Avatar
thnx for the info people!!
kwakers
Feb 4, 2014 11:33 AM
Jeff247
Mar 31, 2009 05:14 PM
Calevra18
Sep 11, 2007 07:00 PM
2002haccord
Apr 12, 2007 11:43 AM
Cr8zychinamin
Jan 13, 2006 06:17 PM
