Sunroof won't close completely
I have an 03 Accord EX V6 sedan. When I push the top button to close the sunroof, it won't close all the way. It stops two or three inches short of closing. I can make it close by pushing the vent button so that the rear of the sunroof pops up, then pushing the top button will close it. Is there any way to adjust the sunroof mechanism?
ahving same issue, havent got to investigate enough but will port my findings. may have to do with 5 pin relay behide drivers side door. Thats my holdup, the white teflon wheel inside door will not rotate to allow opening. everything working ok seems like
So have you guys figured out the problem or did you sell and move on, I just now came
across this and im looking in to the moon roof motor calibration, also could be mixed signals the switch is sending, :/// idk |
for what this is worth...
Moonroof glass is positioned in the OPEN position (or partially open)
Thankyou for your help!!!!! I will see how it goes!
The "Dr" is in the house :)
Dr. Your information seemed helpful but no
Luck sadly the window still does it. |
Thank you !!!
Thank you so much it works for my 2018 Accord 2.0!!!
it was rainy day and thanks to you it’s fixed now. Thanks a lot again :)
Originally Posted by Dr. Drivability
(Post 319321)
| All times are GMT -5. The time now is 02:36 AM. |
