Sunroof won't close completely
Old Jul 8, 2009 | 09:13 AM
dmoak's Avatar
Default Sunroof won't close completely
I have an 03 Accord EX V6 sedan. When I push the top button to close the sunroof, it won't close all the way. It stops two or three inches short of closing. I can make it close by pushing the vent button so that the rear of the sunroof pops up, then pushing the top button will close it. Is there any way to adjust the sunroof mechanism?
Old Nov 1, 2010 | 06:42 AM
byby3g's Avatar
ahving same issue, havent got to investigate enough but will port my findings. may have to do with 5 pin relay behide drivers side door. Thats my holdup, the white teflon wheel inside door will not rotate to allow opening. everything working ok seems like
Old Apr 22, 2013 | 03:57 PM
themickenzie's Avatar
So have you guys figured out the problem or did you sell and move on, I just now came
across this and im looking in to the moon roof motor calibration,
also could be mixed signals the switch is sending, :/// idk
Old Apr 22, 2013 | 04:14 PM
Dr. Drivability's Avatar
for what this is worth...
Moonroof glass is positioned in the OPEN position (or partially open)
  1. Press the moonroof OPEN switch until the moonroof stops in its fully open position.
  2. Release the moonroof OPEN switch.
  3. Press the moonroof OPEN switch again for about 13 seconds .
NOTE: Keep pressing the switch even though the moonroof motor continues to function.
  1. Calibration is complete. The moonroof will automatically move to the regular preset fully open position and come to stop.
Moonroof glass is positioned in the TILT position
  1. Press the moonroof OPEN switch until the moonroof glass stops in its fully open position.
  3. Press the moonroof OPEN switch for about 13 seconds .
NOTE: Keep pressing the switch even through the moonroof glass will repeat an inching behavior (moving 40 mm , then stopping for 0.4 seconds )
Old Apr 23, 2013 | 07:43 AM
Thankyou for your help!!!!! I will see how it goes!
Old Apr 24, 2013 | 06:26 PM
The "Dr" is in the house
Old Apr 25, 2013 | 11:28 AM
Dr. Your information seemed helpful but no
Luck sadly the window still does it.
Old May 5, 2019 | 10:41 AM
Sebag75's Avatar
Default Thank you !!!
Thank you so much it works for my 2018 Accord 2.0!!!
it was rainy day and thanks to you it’s fixed now. Thanks a lot again
jam
Oct 24, 2013 08:11 PM
skijour
Aug 15, 2012 08:31 PM
hodninja
Sep 14, 2011 03:41 PM
miks
May 15, 2007 01:46 AM
krob111
Oct 9, 2006 03:50 PM
