98 accord problems
Old Apr 23, 2019 | 10:27 PM
Raun31's Avatar
Default 98 accord problems
On my 98 accord 4 cylinder its throwing multiple codes ... I replace the eld and change oil and check v tech...but one I press on the pedal is starves any input would help...these are the code 1259, 1298, 0135,0141, 1753,0753
Old Apr 28, 2019 | 07:02 PM
Steisler's Avatar
Look up the codes so you know what your car is trying to tell you, that would be a good starting point........
Old May 4, 2019 | 03:43 PM
Raun31's Avatar
The code its throwing is p1259 I change the vtech sensor and it's still throwing the code
Old May 5, 2019 | 11:44 AM
The Toecutter's Avatar
If stepping on the brake basically kills it, I'd check the wiring to the brake lights. One might be going to ground causing a short.
KimberlyC
Apr 16, 2006 11:51 AM
