Suspension issue! Help!
Old Jul 22, 2009 | 02:49 PM
Dis_aznguywitha_honda
Default Suspension issue! Help!
So i am in the process of replacing my front shocks on my 91 accord ex, got the passenger side done with no problem but i have a problem with my driver side. The rotor seems to be stuck at an angle facing down. The rotor cant move up or down only left to right so i cant put back my upper control arm in place. and also when the passenger side rotor is streight, the driver side is not.
*not - i had my friend step on the rotor to give it clearence so i can take the shocks+springs out.
Is it possible that i damaged the alignment and also something on the rotor that prevents it from moving freely?
Thanks a bunch!
Last edited by Dis_aznguywitha_honda; Jul 22, 2009 at 02:51 PM. Reason: Forgot year and model
Old Jul 22, 2009 | 05:41 PM
The ball joint and outer tie-rod should be able to move freely. Maybe you overextended the CV joint and that is what is preventing you from moving the knuckle.
Old Jul 22, 2009 | 07:32 PM
Yea that could be it. Unless it could be something else also. Anything else that could be damaged?
Thanks for yur input tho.
19962door
Apr 18, 2009 01:31 PM
cOrKinsa
Mar 3, 2009 10:05 AM
manah
Sep 17, 2007 11:25 PM
90f22assasin
Jul 23, 2006 11:38 PM
George Knighton
Jan 11, 2006 08:49 PM
