suspension problem? (added pix)
Old Nov 21, 2007 | 12:28 AM
xpieceofcralpx's Avatar
Almost A Senior Member
Default suspension problem? (added pix)
[[ok, i'm not sure what it is, but theres like a squeaking sound , but not like a high pitched sqeak, but like a spring sound, like when you sit on an old bed our something..and i hear it when i go over speed bumps slowlylike in a parking lot, and when i'm making left turns, so recently i got tired of the sound, so i checked my left tire, where the spring is located, and i noticed what i believe to be is oil buildup at the bottom of the spring, but i'm not sure if this is the source of the sound, or how the heck oil got to my springs, haha, do you guys want me to take pics of it? and post for you to see? ]]
ok heres an update; i took some pics, hopefully you can tell me whats wrong from them..i didnt have time to take the wheel off, so hopefully these angles are ok
Old Nov 21, 2007 | 01:34 AM
Planefreak's Avatar
Default RE: suspension problem?
Pics would help. It sounds like the shock is shot judging by the buildup on the bottom of the spring. How does your suspension feel? Does it continue bouncing after going over bumps? Is there fluid around the shock?
Have you checked out the upper and lower wishbones? The bushings may be worn out.
Old Nov 21, 2007 | 09:05 AM
klrspz's Avatar
sounds like your springs are giving, and your shock's seal blew...
Old Nov 21, 2007 | 09:08 AM
falkore24's Avatar
I'm thinking upper shock assembly bushings ...... not sure of the real part name. Could actually be other bushings also, but those are common for the noise described.
Old Nov 21, 2007 | 09:50 AM
i'll take pics of it soon, just need to take off the wheel, so i can get a better view..does sound like a bushing problem, we'll make sure..
Old Nov 21, 2007 | 03:35 PM
drummer1279's Avatar
Id lean twards a blown strut seal, or just nned a chassis lube.
Old Dec 4, 2007 | 12:03 AM
pics posted on original post..
Old Dec 4, 2007 | 08:30 AM
deserthonda's Avatar
looks like it is time to replace the front struts
Old Dec 4, 2007 | 08:51 AM
falkore24's Avatar
x2 ..... it pee'd on your spring!!!
Old Dec 4, 2007 | 04:52 PM
aww crap, what i was afraid of..sounds expensive.. =/
