Sway bar bushings??
Old Jan 19, 2007 | 02:02 AM
ArcticHonda's Avatar
Default Sway bar bushings??
Just installed new swaybar end links...here are pics of before and after. My question is whether or not the new bushings are tight enough? I couldn't find any rule of thumb in my repair manuals for how much you should squeeze that thing together?
[IMG]local://upfiles/6435/0D21AA86DE7F4C1F9A32AA6722CF1F8B.jpg[/IMG]
[IMG]local://upfiles/6435/734FB30D9C004E60BD13B95344333E87.jpg[/IMG]
Old Jan 19, 2007 | 11:41 AM
deserthonda's Avatar
Default RE: Sway bar bushings??
put a wrench on the bottom bolt and tighten the top nut till tight
looking at the pic after you replaced the bushings , looks like you installed the washers upside down but i cannot honestly tell... the concave ( curved part ) should bo toward the rubber bushing
Old Jan 19, 2007 | 02:45 PM
ORIGINAL: deserthonda
I definitely put the washers with the concave portion on the bushing side... I used the 2nd assembled end link as an examply while installing the 1st side. I tightened it all together unitl the bushings are touching but not squished.
Old Jan 19, 2007 | 08:38 PM
hondadude's Avatar
Well I think you do want the rubber to Squish, so that it will hold the sway bar. As in; fill up the hole in the bushing hole of the sway bar/control arm
Ialways run the nut down to the end of the threads.
Old Jan 20, 2007 | 04:45 AM
wietgr's Avatar
I just replaced mine last month and did not get them tight enough and still had noise. I put a wrench on top and ran them down with my 3/8' impact till they were squished and no more nosie.
Old Jan 20, 2007 | 04:17 PM
Cool thanks for the advice, I'll crank the nut down to the end of the threads and then post a new pic. HondaDude, is that really a picture of you in your avatar? (LOL)
Old Jan 23, 2007 | 03:56 PM
Ok, I cranked down the nut to the end of the threads and squished the bushings together. I'm pretty sure this is how its supposed to be.
[IMG]local://upfiles/6435/0FD3836F2D7A4D7A98B8E5CB4F5B9B4E.jpg[/IMG]
Old Jan 23, 2007 | 04:23 PM
Enlarging the picture i can now see that you got the washers installed wrong,, the curved part should go toward the rubber bushing ,, they look upside down to me
Old Jan 23, 2007 | 07:14 PM
hondadude's Avatar
ORIGINAL: ArcticHonda
the one and only , see what working on hondas can do to a guy, I used to be young and handsome;
and that is also a picture of Deserthonda in his avatar LOL
Old Jan 23, 2007 | 07:23 PM
maro's Avatar
without seeing that you need sway bar end links/bushings. What are the symptoms that occur to warn you?
