synthetic engine oil = better mileage?
Old Jun 9, 2008 | 04:03 PM
faosh's Avatar
Default synthetic engine oil = better mileage?
I heard in a TV program that synthetic engine oil results in higher fuel efficiency. If that's true, (and not to mention that it lasts longer) synthetic oil might be the way to go purely from a monetary point of view!
Old Jun 9, 2008 | 11:21 PM
Default RE: synthetic engine oil = better mileage?
Theoretically true, but barely any difference. Long oil-change intervals should be supported by oil analysis.
Old Jun 10, 2008 | 02:29 PM
00AccordLX5spd's Avatar
Registered User
Simple answer: No. You will not be able to tell a difference in gas mileage. You won't be able to tell a difference in anything at all for that matter. no you will not get better horsepower either. All of that is merely a sales gimmick used by Synthetic oil manufacturers. The only thing you should notice is your wallet getting lighter when you buy the syntheticoil, and you will possibly sleep better at night going over 3000 miles between oil changes.
Old Jun 10, 2008 | 03:35 PM
Dang Jon, howd you do that. It wont let me post more than 12 words at a time.
Old Jun 10, 2008 | 04:18 PM
Registered User
I don't know. It is allowing me to post more words all of a sudden. I think it may have something to do with the order in which you respond. i.e. if you are the first person to respond on a thread, it only lets you write a few words.
Old Jun 11, 2008 | 05:41 PM
brayner's Avatar
Synthetic_oil_is_a_good_alternative._Most_on_this_ forum_don't_support_its_use.
You_need_to_get_good_oil_analysis_data_to_support_ a_longer_change_interval_(the_main_benefit)._Don't _look_for_it_on_this_forum._
I_have_a_high_mileage_Accord_and_won't_risk_switch ing_because_of_the_oil_seals.
Old Jun 12, 2008 | 08:35 AM
falkore24's Avatar
^^^ Don't do that please!
If you have a snail under the hood, synthetic oil is better because it won't cook at such a low temp. Often it eliminates the need for a turbo timer when an oil cooler is included.
Old Jun 12, 2008 | 08:48 AM
whododat's Avatar
So in other words, all the research/analysis done with synthetic oils is nonsense? I don't agree.
Old Jun 12, 2008 | 09:24 AM
This_is_the_only_way_itll_let_me_post_for_now...
Synth_oil_IS_better_but_that_doesnt_mean_its_NECES SARY,
for_stock_non-turbo_cars.
Old Jun 12, 2008 | 09:55 AM
falkore24's Avatar
^^_That's_crazy_...._I've_been_having_trouble_too_ ..._I_didn't_think_it_went_by_word_count!____Now_i t's_doing_it_to_me_too.
I_agree_with_Jim_...._better,_but_most_often_unnec essary.
