Temp Gauge unresponsive
Old Mar 13, 2013 | 01:51 PM
Movian's Avatar
Default Temp Gauge unresponsive
Hi, my 01 accord 3.0 v6 has an unresponsive temperature gauge, it has no response from when the car is started til stoped.
Ive Checked Voltage readings from each of the sensors and it appears all of them are working, diagnostics say that the engine is still being cooled properly.
Any ideas?
Old Mar 13, 2013 | 06:55 PM
Check that temp sensor is plugged in. I don't know location on V6, but no response indicates an open circuit. Could be open sensor, disconnected sensor, broken wire, or failed gauge panel circuit. Sensor is usually located near the thermostat.
Old Mar 13, 2013 | 07:50 PM
Something in the back of my mind.... so I checked parts drawings.
The sender for the temperature gauge is a 1-wire sender in the thermostat housing. Shown as #13 in the picture.
BUT... for 2001 the parts list DOES NOT show #13. So I think that the ECU uses its water-temperature sensors and drives the temperature gauge.
So if all the sensors read OK with a scanner, then I'm guessing it's a bad connection to the back of the gauge cluster. Did you check the sensors with an ECU scanner or did you just use a DMM to measure the sensors themselves?
Old Mar 13, 2013 | 08:20 PM
First, check the No. 9 fuse in the driver's side under-dash fuse/relay box.
98-99 Accords uses an ECT sending unit, 00-02 Accords uses the PCM.
Here is the Engine Coolant Temperature gauge circuit description for the 00-02 Accords:
The engine coolant temperature gauge has two intersecting coils wound around a permanent magnet rotor. Voltage applied to the coils, through fuse 9 (in driver’s under-dash fuse/relay), generates a magnetic field. The magnetic field, controlled by the PCM, causes the rotor to rotate and the gauge needle to move. As the PCM varies the current, current through the gauge coils changes, moving the gauge needle toward the coil with the strongest magnetic field.
Old Jun 19, 2013 | 09:37 PM
Movian's Avatar
Im thinking it must be somewhere in the wiring, being disconnected i changed out the guage cluser it still doesn't work.
pirulino23
Nov 10, 2010 06:18 PM
raf105
Sep 28, 2007 02:55 PM
corr04
Jun 7, 2006 01:24 AM
honker3
Dec 6, 2005 08:33 PM
fperezal
Sep 29, 2005 09:29 PM
