temperature control on 93 Accord SE
The temperature control know on my wifes 93 Accord SE was stuck and would not move to heat the car this winter. After reading this forum I was able to open the flapper on the right side of the console and turn on the heat.
Now, it's late April and yesterday, after driving it I decided to see if I could move it to cool. After not much resistance the knob moved freely, but doesn't change the temperature. (It's still hot.) Now, the knob moves without any resistance. Did the cable break, come loose, or what? Any suggestions will be very helpful. Thanks, Tom |
RE: temperature control on 93 Accord SE
Can't tell from here whether it's broken or disconnected. You probably moved the lever down near the cable #12? That cable #12 goes out thru the firewall to the water valve.
http://www.hondaautomotiveparts.com/...SM40_B1720.gif Thefirst cable (not shown here) that goes from the control lever down to that lever shown here. Look for that to be disconnected. Worst case is some lever or bellcrank is actually broken. It doesn't look like there's a lot of individual parts available separately. Maybe a junkyard?? |
