TEmperature guage when close to red mark
ORIGINAL: JimBlake
Just from the thermostat I can't imagine losing more than a gallon. There's only about 2 gallons total.
But if it's been awhile, this makes a good excuse to drain & change it completely.
I have a 93 accord and I'm going to drain the coolant, so I have 3 questions
1. where is the drain cap or bolt.
2. whats the correct mix of water and coolant, 50/50? or should i just add coolant unmixed?
3. The coolant I bought says its already diluted with water, do I still mix it with water or just add it?
4.what is my radiator capacity, in other words how many galons of coolant should I add or how do i know I've added enough.
Thanks for ur help.
Thanks for ur help.
There should be a drain in the bottom-center of the radiator.
Probably another one (to drain the block) on the back of the engine block, near the oil filter. (possibly varies with year & I never owned a 93)
50/50 is correct, and if you have the stuff that is pre-mixed that is probably just what it is.
The capacity is in the owner's manual somewhere, it's probably between 1.5 & 2 gallons.
dre2430
Apr 21, 2011 11:01 PM
Karthigan
Nov 27, 2006 02:55 PM
