Temporarily increasing idle
Old Jan 13, 2016 | 03:38 AM
nottaj's Avatar
Default Temporarily increasing idle
2002 Accord SE 2.3L auto
I don't know anything about anything.
I'm trying to power a digital projector through an inverter. At idle, the alternator does not output enough power to maintain this. I want to increase the idle temporarily, for the sole purpose of idling, parked, for a couple hours at a time to power the projector, and then bring the idle back down afterward.
Basically, I want to use my Accord as a stationary generator for short periods, and need to increase the idle to do so.
However, I read this post and other info elsewhere that suggests the ECU/IAC will fight to keep the idle low.
Is this the case?
What is the procedure I should go through to accomplish this?
Do I need to disconnect the IAC?
Will I need to go through the whole process of resetting the ECU every time, or is there a simpler solution for my situation?
Merci beaucoup.
Old Jan 13, 2016 | 08:30 AM
A small shim inserted behind the throttle plate stop will cause higher idle. You will need to experiment w/ different thickness shims. Suggest a strip of plastic cut from a container as shim. May need to glue a couple together to get enough idle increase.
Install by manually rotating throttle plate and inserting shim between throttle plate stop and idle stop screw. Don't attempt to adjust idle stop screw as this will cause other problems.
See attached graphics.
File Type: pdf
File Type: pdf
xang0
Jul 6, 2009 03:22 PM
accord485
Dec 30, 2008 02:39 PM
cyberdork
Oct 29, 2008 12:19 PM
Styl3zt
Oct 17, 2007 09:14 PM
letas87
Feb 24, 2007 08:24 PM
