Tensioners
Old May 4, 2007 | 11:39 PM
jstehle
Default Tensioners
Hello is it neccessary to change the two tensioners when you replace the timing belt? Or can you just use the old ones. Thanks
Old May 5, 2007 | 01:02 AM
hondadude's Avatar
Default RE: Tensioners
They will usually make it to the second T-belt change.
You can spin them slowlywhile off and feel for a rough spot; also the seals can be gently removed and some fresh grease smeared into the bearing.
bcjammerx
Jun 1, 2019 02:24 AM
tallgood
May 8, 2007 03:12 PM
hatzipri
Nov 20, 2006 06:23 PM
