Throw outbearing ....
Old Sep 7, 2011 | 02:15 PM
D-ODD-1's Avatar
Default Throw outbearing ....
Trying to replace my clutch today and came along this issue the old throw out bearing is worn out. But the fork moves freely. Is there a part missing ?
Old Sep 7, 2011 | 04:15 PM
Not sure what you mean the fork moves freely. It's supposed to move freely, but kinda held by the spring inside the clutch slave cylinder. Once you remove the slave cylinder, the fork almost flops around loose.
Old Sep 7, 2011 | 04:20 PM
piggylover1985's Avatar
The fork looks okay, looks like a little springgy thing behind the fork is there.
Old Sep 7, 2011 | 05:04 PM
T-O fork sits on a ball-&-socket. The spring #8 holds it onto the ball #7 so it doesn't fall out during assembly.
Old Sep 7, 2011 | 09:08 PM
D-ODD-1's Avatar
So that nut #7 is not needed then ? cause the throwout bearing as u can see is rubbing.
Old Sep 7, 2011 | 09:17 PM
#7 is actually a ball not a nut, even though it looks like one :-). #8 fit inside #6 and snap into #7.
Old Sep 7, 2011 | 09:40 PM
D-ODD-1's Avatar
Okay so let me post one more pick
Old Sep 7, 2011 | 10:46 PM
I never replaced my clutch on my accord, so I don't know. Make sure you use the proper grease for the shift fork and splines on the transmission. It is high temperature lithium or high temperature urea grease. Don't use regular grease, it will dry out over time.
Old Sep 8, 2011 | 08:51 AM
The pivot ball #7 IS NEEDED.
The spring #8 holds the fork onto that ball so it doesn't fall off during assembly.
Old Sep 8, 2011 | 10:17 AM
D-ODD-1's Avatar
Okay thats where i was confused like hell. Cause when u remove the slave cylinder that fork moves in every direction and when we removed the transmission. The old TOB was worn out on the sides.
Now the trans is back up and all. Some Trans oil leaked so my question is can i use Syncromesh or should i use 10W-30
