Ticking sound
Old Oct 19, 2007 | 11:57 AM
  #21
falkore24's Avatar
Default RE: Ticking sound
In Canada, I'd go with the 5W20 oil. If either works, thinner is better for cold winters. Since it's likely never been done, I'd do an engine flush before your oil change, use dino oil for this round with 1 qt. of Marvel Mystery Oil and next oil change, do a 5 minute flush without rev'ing at all. This will get your crankcase and lifters nice and clean. MMO is awesome stuff!
Old Oct 19, 2007 | 02:07 PM
  #22
Try using a short piece of tubing to use as a "stethoscope" and localize the sound. Do the V6's have solid or hydraulic lifters? If hydraulic, there a some additives that are advertised to help relieve lifter noise.
Old Oct 19, 2007 | 08:20 PM
  #23
nafango2's Avatar
if its a fast clicking that sounds kind of like someone typing really fast on a loud keyboard the valves need to be adjusted.
Old Oct 20, 2007 | 09:19 AM
  #24
daniel216's Avatar
hey guys, the problem was solved when i changed the PCV valve. just one more question, im about to change oil, how much liters of oil should i fill?
Old Oct 20, 2007 | 09:52 AM
  #25
deserthonda's Avatar
about 4.3 liters ..........or 4.6 qts
Old Oct 20, 2007 | 09:54 AM
  #26
daniel216's Avatar
isnt 4.3 liters for the 4cyl models?
Old Oct 20, 2007 | 07:19 PM
  #27
daniel216's Avatar
Old Oct 20, 2007 | 08:06 PM
  #28
ORIGINAL: daniel216
No need to ask the same question more than once,,,,,,,,,,v6 engine takes about 4.6 qts of oil,, which is about 4.35 liters ..
Old Oct 20, 2007 | 10:51 PM
  #29
nafango2's Avatar
looks like it was accidenal. they posts are exacly the same.
Old Oct 22, 2007 | 11:17 AM
  #30
falkore24's Avatar
9.5 hours later?
