Tightened neg.post of battery, now won't crank?
Old Dec 16, 2007 | 01:33 PM
razcob's Avatar
Default Tightened neg.post of battery, now won't crank?
I started the car this morning and turned it around. I opened the hood, and noticed the neg. cable was loose, so I disconnect cable and clean with wire brush. I do the same cleaning with positive post. I ensure the fittings are clean and tight. I insert key in ignition and it won't turn over and there is no starter noise. I turn key to 'on' and hear a slight hum. I also notice that when I attempt to start the "P" and "D" shifter light are both on, then "D" light goes out. I checked every fuse on drivers side and in engine compartment. I took a rubber tipped pipe and hammered the starter a few times. Voltage of battery is ~12.6 volts. I also moved shifter from "P" to "N" and attempted to start. No prior symptoms. Any suggestions?
95 Accord EX, 2.2 4cyl, ABS, auto
Old Dec 16, 2007 | 04:08 PM
razcob's Avatar
Default RE: Tightened neg.post of battery, now won't crank?
As is true with every backyard mechanic, there comes a time when he must humbly admit he overlooked the obvious. When I disconnected the battery, I forgot to reset the alarm by pressing the remote. It starts fine now.
Old Dec 16, 2007 | 04:16 PM
00AccordLX5spd's Avatar
Registered User
lol. Stuff like that happens to me all the time. Me - "Why won't it crank! Stupid car!" My mind - "You forgot to hook the battery back up when you were done working on it"
Old Dec 16, 2007 | 06:05 PM
drummer1279's Avatar
Me - "WHere is that GoD#@$% bolt!? I LAID IT RIGHT THERE!....oh...there it is in the tray with the rest of them"
Old Dec 16, 2007 | 09:48 PM
nafango2's Avatar
haha ive done stuff like that.
When I did a valve adjustment I forgot to plug in a plug that gives power to the injectors, then when i went to start the car i was like "WTF!?!?!?"
Old May 7, 2017 | 08:37 PM
Ed Wolverton's Avatar
Default 95 accord won't start
i bought a 95 accord ex that ran great but a engine dash light was on so I figured I would take neg cable off to reset now my car won't start
Old May 7, 2017 | 08:39 PM
how do I reset alarm on 95 accord
Old May 7, 2017 | 09:08 PM
The 95 accord doesn't have a factory alarm system. If your car has an alarm system, it is either an aftermarket alarm, or maybe a dealership accessory.
What happens when you put the key in the ignition? What happens when you try to start it?
Old May 7, 2017 | 10:15 PM
  • When I put key in try to start it dash lights come on but it won't turn over plus its blinking 15 times
Old May 8, 2017 | 11:50 AM
Celicool's Avatar
an alarm reset procedure can be model specific. Try google with your specific alarm brand keyword and see if the general reset instruction would work for your car. If you are not familiar with the alarm operating instruction, chances are good that you will have more problem with it in the future.
If all fail, you can just dig into your steering wheel column harness (this is where an alarm system usually intercepts your starting circuit) and reconnect your start wiring. This may also mean disabling your alarm.
fudads
Feb 27, 2013 07:36 AM
mamtsberg
Sep 10, 2012 08:58 AM
hack
Jul 12, 2011 06:12 PM
xang0
Jul 6, 2009 03:22 PM
elderfoster
May 25, 2009 02:44 AM
