timing advanced, but not. 92
Old Apr 26, 2013 | 09:17 AM
BlindGungfu's Avatar
Default timing advanced, but not. 92
So ive checked all my timing marks, even balance shaft lines up nice.
But when I set timing with light, I make distributor all the way advanced, and its about halfway between white line and red line.
I get a lot of pinging going up hills, cant accelerate very well...
im assuming something factory is out of wack and I need to move cam a few teeth, but not sure if it will damage anything.
Old Apr 26, 2013 | 10:10 AM
Dr. Drivability's Avatar
are you shorting the service check connector to take the ECM out of the loop. that's what needs to be done to set the base timing correctly.
Old Apr 26, 2013 | 11:25 AM
Yes, jumper wire is being used
Old Apr 26, 2013 | 11:44 AM
I suspect the distributor is misaligned by 180 degs. I didn't think it would start or run w/ that alignment, but perhaps it's possible.
Old Apr 26, 2013 | 11:57 AM
good point texas. pull the plugs, bring no. 1 cylinder up to tdc and then pull the cap and see where the rotor is pointing. is it pointing at the no. plug wire contact? you may have to restab the distributor.
Old Apr 26, 2013 | 01:38 PM
um, the teeth on dizzy that plug into cam are offset, so it cant go in wrong.
(checked before posting)
not to mention it probly wouldnt start, and if it did, would die if u touched it lol
Old Apr 26, 2013 | 01:51 PM
oops, my mistake, was thinking of something else, pontiac, sbc, dodge...LOL!
you should do the tdc rotor check anyway just to confirm.
Old Apr 26, 2013 | 02:24 PM
did. same prob.
tripple confirmation teeth are offset
Old Apr 26, 2013 | 02:43 PM
You checked and distributor rotor is pointing towards No 1 spark plug cable connector w/ crankshaft pulley aligned to 15 BTDC?
If yes, then distributor rotor may have sheared. It seems possible, but I never heard of this.
It is possible to install the distributor rotor off by 180 degs. Guess how I know
Old Apr 27, 2013 | 10:29 AM
Ha, my bad read that wrong. Ill do the check.
Musta tightened it pretty hard to get it in there like that... Lol.
