Timing belt
Just a quick question for you guys. I hope this is in the right place. What does it usually cost for the timing belt replacement?? My car has 175k on it, I figure it won't be long before I need to have it done--I drive a lot. I know the water pump should also be replaced, anything else? I will probably take it to the dealer, I figure for something this important I want to be sure it was done right.
Thanks. |
RE: Timing belt
350 - 500
RE: Timing belt
it all depends on the year and model.........but since we do not know we cannot give you an accurate response........
Input the year and model on your signature that way we will all know what year you are asking about |
RE: Timing belt
Good idea about the signature :)
Now I dont have to remember to post the that info. |
RE: Timing belt
thanks for inputting year and model :)
the timing belt kit for your car should include timing belt balancer belt water pump coolant valve cover gasket upper spark plug seals cam seal balancer shaft seal + retainer crank seal rear balancer shaft gear seal alt + p/s belts if a dealer does the job the price might vary depending on where you reside but be ready to spend over 500 dollars .......... if a honda specialty shop does the job it should be a bit cheaper but make sure that they use Honda parts I would not let any other shops do the job other than the 2 i mentioned IF you do the job you can save a lot of money... |
RE: Timing belt
Cool....I was just hoping it would stay under $1000.....
I will probably let the dealer do it, I want it done right. I try to work on my car myself as much as possible and learn in the process, but the complexity of this job and the fact that I have to be able to drive my car often just doesn't mix well. I am still a learner/do it yourself mechanic....gotta know where to draw the line. Thanks for your help! |
RE: Timing belt
very intelligent reasoning. a+
RE: Timing belt
What you try to do is to cultivate one of the better Honda Techs into doing your job on the side which is about what most of the dealer ships techs do to make that extra $$$$
WheelBrokerAng [sm=americanasmiley.gif] |
RE: Timing belt
ORIGINAL: fireballer44 ... I try to work on my car myself as much as possible and learn in the process... |
| All times are GMT -5. The time now is 06:19 AM. |
