-   -   TPS Problem or Transmission problem? 2001 ACCORD (https://www.hondaaccordforum.com/forum/general-tech-help-7/tps-problem-transmission-problem-2001-accord-49685/)
trouble Aug 20, 2012 12:42 PM
Hi Everyone,
I have 2001 Honda accord EX. For the past 2 weeks, for the first 2 minutes, only when the engine is cold, I will have hard shifting from 1-2 and a high rev into those gears. I'll pull out of my parking spot, put the car in to drive and it will rev past 3k rpm, then jerk into 2nd. If I wait for the car to fully warm up it, everything will work perfectly and all shifts are smooth. The other day, it was rainy and the problem was the worst I have seen, it ended up putting my car into LIMP mode and gave a code 7 ( seven long blinks). I did a sweep test with a voltmeter to my TPS and it seems fine; however it did jump up in voltage between .40 V to 1 V a lot faster than 1V- 5V. What could be causing this problem?
Any help would be greatly appreciated.
poorman212 Aug 20, 2012 08:17 PM
First, the 98-02 trans in these cars does not have a good rep.
Did this "code 7" come from the D4 or the CEL? I'd suggest getting the codes read from a parts store and get the actual code from them and not their description....."P" and four digits....P0973 or something like that. The OBD-II codes are a bit more descriptive.
My next question would be, when was the last time the trans fluid was changed and please tell me Honda trans fluid was used.
trouble Aug 21, 2012 10:34 AM
I recently did a 3x drain and refill when the problem first started to occur. The level may be a little high, it hits the upper mark; but this problem also occurred when it was in between the upper and lower marks. Also, when I did the ATF there wasn't much metal shavings or any chunks... so I'm hoping not a trans problem.
poorman212 Aug 21, 2012 07:46 PM
Did you use Honda Trans fluid?
