TPS question
Old Feb 14, 2006 | 02:26 AM
marbro's Avatar
Default TPS question
ok, other then the idle being off what is the major problems that occur when either the input is high, or input is low? Reason I ask is because I'm trying to find the reason my tranny isnt shifting properly after changing the throttle body. If the tps being off is the problem then thats easy to fix, if its not the problem....... well...... there is a major problem that isnt throwing a code..... and ill probably do an auto to manual swap. Dont want to waste the time to make a test harness to get the voltage right if it isnt directly related to the problem.
Old Feb 14, 2006 | 02:48 AM
Default RE: TPS question
Well let's start with this info for you...about the TPS-it measures the throttle movement and it's signal is used by your vehicles engine control (ECU) to adjust the ignition timing, fuel mixture, and torque converter lock-up.
A bad TPS can result in problems such as hesitation, stalling, eratic idle, pinging, and no torque converter lock-up, also hard starting, and a intermentent check-engine light (which you say your no getting codes).
This doesnt sound like the real problem but for a few bucks you can change the TPS and see if the problem rights itself...
WheelBrokerAng[sm=americanasmiley.gif]
Old Feb 14, 2006 | 04:48 AM
marbro's Avatar
It is throwing a code for the TPS 7 short blinks. I was just saying if there is a major problem that isnt throwing a code I was going to have a big problem then. ^_^ As for it being a bad TPS I dont think thats the case, but can the TPS being over or under cause the transmission to shift prematurely? or some cases not until it hits a specific rpm. About the only problem is the fuel mixture seems to be running very rich.
The thing I am finding odd is the transmission not shifting properly only existed after changing the throttle body. The park shift lock also stopped working after changing just that. But I view that as an added secruity feature. ^_^ After all nothing wrong with someone not being able to steal my car cause they cant get it out of park.
I need to replace the TPS anyways, seeing as my friend cracked one of the sides when he felt the need to drill it out, but I am unsure of what model to buy seeing as honda only sells the TPS attached to the throttle body for 98 accords and im sure many other hondas.
cwfmmr
Oct 11, 2013 11:43 AM
live2rice
Jun 26, 2008 05:25 PM
Tai_Boi
Mar 29, 2008 01:08 AM
copperhead
Mar 26, 2007 09:47 PM
marbro
Feb 6, 2006 09:28 PM
