Traction Control System (TCS LIGHT) question
Old Nov 8, 2006 | 12:02 AM
jlmartin42
Default Traction Control System (TCS LIGHT) question
I have a 2003 Accord EX and about two weeks ago the TCS light came on. Now when I start the car and press the brake to put it in gear, the light comes on and the gear locks up and will not let me put it in drive. I then have to turn the car off, press the brake, and restart the car with the brake pressed to get it in gear. Basically, I cannot figure out why the light comes on and locks up the transmission. My only thought is that I have a tire with a slow leak and it is triggering some type of wheel sensor. Any help would be greatly appreciated.
Old Nov 8, 2006 | 12:26 AM
YeuEmMaiMai's Avatar
Default RE: Traction Control System (TCS LIGHT) question
the safety interlock is not being disabled for some reason. Culprit might be the brake switch under the dash......
Old Nov 8, 2006 | 09:06 AM
Chiovnidca's Avatar
Check eingine light on also? What trouble code does it have stored? Do the brake lights work when it's acting up?
Old Nov 8, 2006 | 01:48 PM
sir_nasty's Avatar
first off welcome to the forum and thanks for posting the model/year!! Like they said have someone get out of the car and look at your brake lights, if they don't come on when you push on the brake and try to shift then you have a brake switch issue.
Does the car run normally/just fine after you get it started/in gear?
Old Nov 8, 2006 | 06:43 PM
jlmartin42
Thanks for all the replies....To answer all the questions, 1) my check engine light is not on 2) I have no clue about the codes and 3) I am not sure about the brake lights either...Ill have to check. However, my brake light was out and I just replaced it...Don't know if that would have anything to do with it? Is the brake switch issue something I can fix or do I need to take it to the dealer?
Old Nov 8, 2006 | 09:38 PM
sir_nasty's Avatar
you could easily repair the brake light.... pretty quick/simple... I doubt replacing a bulb would cause this.... check the brake lights and let us know
barticus520
Oct 24, 2014 04:45 PM
anyt777
Sep 16, 2013 06:16 PM
Salzar540
Mar 31, 2011 09:11 AM
H22A Accord
Sep 5, 2010 02:45 AM
freightliner009
Mar 30, 2010 05:25 PM
