Trailering a popup camper, 01 4cyl..?
Old Jul 29, 2011 | 05:42 AM
tnci's Avatar
Default Trailering a popup camper, 01 4cyl..?
I'm considering a "popup" type camping trailer, something with ac/heat unit. Car is an 01 4cyl auto, 156k, rust free, good condition. Would a suspension "upgrade" be beneficial, and, if so, what parts? HD shocks, stabilizer rubber? Understand trans fluid will need frequent c/o.
Yes, the lighter the camper, the better.
Thanks for input...
tnci
Old Jul 29, 2011 | 09:45 AM
bigpat's Avatar
Almost A Senior Member
I would suggest that you install a transmission oil cooler and take a good look at the radiator/cooling system on the car...Those two are suspect in this situation...Front brakes as well !!
Old Jul 29, 2011 | 09:54 AM
moey's Avatar
I dont think accords have a towing capacity but I could be wrong. I wouldn't tow much beyond what the weight capacity in the car states in the door. Also make sure there is very little weight from the tongue on the car, like almost none.
Old Jul 29, 2011 | 11:33 AM
Owners manual should have towing capacity. It's not particularly large, but it isn't zero either. Maybe 1000 pounds with 100 pound tongue-weight.
soba_03
May 27, 2014 04:52 PM
kenwood guy
Sep 15, 2013 03:02 PM
PhagnaScotty
Apr 1, 2008 10:30 PM
jasonsaccord
Mar 26, 2008 08:52 AM
RTexasF
Mar 6, 2005 11:59 AM
