tranny swap
Old May 19, 2009 | 01:41 PM
Et5291's Avatar
Default tranny swap
Does anyone know what the price on a 5 speed swap for my 95 accord 2.2 i lost my transmission and i have to get a new one so i was wondering what the 5 speed job would run me thanks
Old May 19, 2009 | 02:00 PM
To have a shop to do it? Or just for parts? To pay a shop to do it your probably looking at $1,500-$2,000 as its a bit of labor, the parts them selves arent that expensive though.
This is what you will need:
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord, 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord, 92-96 Prelude)
7. 5 speed brake pedal arm (90-93 Accord, 94-97 Accord)
8. Clutch master cylinder w/ reservoir and lines (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to Honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00)
18. MIG WELDER
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
Old May 19, 2009 | 02:06 PM
Et5291's Avatar
well i was thinking that my friend and i can do the job its just the transmission itself and the parts to go with it. what would the difference in cost be if i just dropped another auto in there. i was considering buying a 5sp prelude anyway so idk what i'm going to do yet
Old May 19, 2009 | 02:08 PM
I dont know I mean you could probably get an automatic for $300ish. Compared to $300ish for a manual, and then if you just went to a junkyard and could find a 5spd accord could probably get the rest of the parts for 2-300 maybe.
Old May 20, 2009 | 08:00 AM
Et5291's Avatar
ok cool and where would you recomend getting the transmission for the automatic
Old May 20, 2009 | 09:15 AM
best bet for cheapest would either be a junkyard or craigslist, just have to know what you are getting.
Old May 20, 2009 | 10:49 AM
Et5291's Avatar
ok thanks ill have to look cause i know i can get a new one for around 1000
Old Jun 21, 2009 | 12:49 AM
cawb09
I have a '99 V6 Accord. Would i be able to do a transmission swap on that? They didn't start making a manual transmission on a V6 Accord until 2003, unfortunately.
Old Mar 21, 2010 | 03:54 PM
AhhCord9697's Avatar
To: ET5291
Have you done the swap yet?
Old Mar 21, 2010 | 04:01 PM
I have a 96 EX Accord that was t-boned and, I am trying to buy another Accord that is a 96/97 EX 5sp sedan but, its so hard to find those in a 5sp it sucks!!!
So I am trying to figure out if I should just get an EX automatic and do the swap? or get a SE and do the engine tranny and just basically the whole swap.
I also want to know if the motor has to be taking out to be able to do the Swap? I might as well do that if I get an SE version of the car, because those are a nonVTEC engines. Also I just got a new clutch before I was hit by this B**** who ran into my driver side doors hitting right at me while I was driving.
SO Thanks for anyone who can give me much more advice on this. Thanks Live2Rice for the parts needed for the swap. I am wondering what is that, that needs to be weld on?
18. MIG WELDER
Let me know more about that one.
Thanks!
