Trans fluid leak
I have a small transmission fluid leak. It appears to be coming from what I believe is the speedometer cable adapter that is mounted at the bottom of the trans. Is it possible to leak there? I am not sure if there is a gasket/o'ring there or not. I can't find an exploded view of the part. Any help would be helpful.
Thanks
Danny
2002 Accord Coupe EX Auto
Thanks
Danny
V-6 or 4-cyl engine? Those may as well be completely different cars, especially as far as the transmission is concerned.
Anyway, did you get the axle out of the steering knuckle to tap it back into the differential? That's a big part of the job.
Drain trans fluid ('cause it'll just run out of the axle opening). Remove axle. Pry out the seal. Press in a new seal. Put it all back together. Don't forget to put fluid back in the trans.
Sure, lots of people have had to replace axles, mostly for bad CV joints. But sometimes the surface where the seal presses, gets corroded, damaged, or ????
Originally it was because the axle wasn't snapped in all the way? Had you done some work? Did it just pop out by itself? If it was partly popped out for awhile, that can damage the seal, but it seems kinda strange for that to damage the axle.
