Transmission 01 accord v6
my accord 01 v6 only engage in d2 after driving for 2 min upshift to d4 everything start working fine ,ATF oil is clean ,gear shifting fine after this ,please help using it this way for 5 months now. mind my English please
I know you said the ATF was clean but from the sounds of it - I would do a drain and fill of the trans fluid and use Honda trans fluid. Also be sure it is at the proper level after the change - Honda does have an odd way of checking the trans level.
I've seen/read of cold shifing issues in Honda auto trans when non Honda trans fluid has been used.
Hello Guys i did the flush the shift in the delay actually reduce but still exist , but in the morning i do remove the fuse no 6 at the driver side,when i did this the trans will enter d1 and move but when fuse is back will have a delay shift .
Leave the fuse alone, just confusing things. Plus we might have different manuals and #6 drivers under dash might be something else in the manual you have.
When you changed the fluid, what did it look like...smell like? Might need to do another drain and fill
As stated before, the auto's trans in this gen did have more issues than any of the others. So I' hoping fresh fluid will cure the "cold shift" issues. Again if the only issue you are having is when the trans fluid is cold you have a shift delay, I'm still with the fluid. But I'm assuming you have no codes and no other issues with the the trans.
